-   Hotrodders' Lounge (http://www.hotrodders.com/forum/hotrodders-lounge/)
-   -   LINE LOCK (http://www.hotrodders.com/forum/line-lock-14471.html)
BIGBLOCKSTANG 11-05-2002 07:10 AM
LINE LOCK
IS THERE ANY PROBLEMS USING A LINE LOCK FOR YOU EMERGENCY BRAKE INSTEAD OF CABLE ANY HELP THANKS :) :)
1meancuda 11-05-2002 07:16 AM
Well, I'm not sure but don't you have to actually have the car on to use the line lock?
Centerline 11-05-2002 11:24 AM
The only problem using a Line Lock as an emergency brake is that it isn't designed for that purpose. The line lock is a selonoid based system that works by locking the pressure to the front brakes. It may or may not hold pressure over an extended period of time and if it doesn't and you're parked on a hill... oh well.... Your emergency brakes on the other hand are mechanical in nature and the chances of failure under normal conditions are almost zero. Also you probably wouldn't want your insurance company to find out you're don't have an approved emergency brake system either. <img src="graemlins/sweat.gif" border="0" alt="[sweat]" />
Centerline
<a href="http://www.hotrodsandhemis.com" target="_blank">http://www.hotrodsandhemis.com</A>
Fry 11-05-2002 02:28 PM
my local laws state something about your emergency brake has to be able to hold your vehicle on a so many degree angle or something. I would check local laws just incase.
4 Jaw Chuck 11-05-2002 05:14 PM
In most cases a normally closed valve would have to be fitted instead of the normally open type usually used. I think to meet the law you would have to have both front and rear systems actuated together or else you could face a locked rear braking system at highway speed if it fails.
Air brake systems on semi's are similar I believe (correct me if I am wrong) and they are legal. There are pinion type disc brakes that can function as emergency brakes, I think this would be a better bet for a rod.
Why do you want to do this? Is there a reason why your mechanical system has been disabled/removed?
BIGBLOCKSTANG 11-06-2002 09:55 AM
I AM RUNNING A TARUS MASTER CYL AND 78 CAD BRAKES PEDAL WONT GET HARD STILL SPONGY WITH BRAKES INSTALLED :(
1meancuda 11-06-2002 10:05 AM
Although I can't tell you what the problem is with the brakes, I can tell you to stop shouting! ;) Seriously, the Caps Lock key is right under the Tab key!
Just giving you a hard time!!! :D ;)
BIGBLOCKSTANG 11-06-2002 12:10 PM
:) Better
