Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - line lock
Thread: line lock
Old 10-09-2006, 07:41 PM
poncho62's Avatar
poncho62 poncho62 is offline
Wiki Edits: 5
Is your dragstrip on a hill?....It shouldn't roll, unless your clutch is grabbing a bit, Check this first.
The linelock holds the front brakes on as long as you are holding the button down....As soon as you release it, they release the brakes. You will need to peactice a bit to release just as you are hitting the gas and releasing the clutch.
