Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - line lock
Thread: line lock
Old 10-10-2006, 03:44 PM
proge proge is offline
Originally Posted by dgcantrellsr
Install line lock on front tires, when you stage, hit brake pedal and hit button on line lock, this should hold car still, then you can work gas pedal and clutch separately,don't get in any hurry cause you got a second and a half till green comes on,when you dump clutch(on last yellow bulb), let off button.
Also I think you may be able to hold button down and still hit brake and it will hold. You can experiment on that.
Been many moons since I ran a four speed, on the strip, Glide w/transbrake is the way to go, less breakage.
I will try it when I get it thank you very much proge
