Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - line lock
Thread: line lock
Old 10-17-2006, 11:25 AM
Quarter Flash Quarter Flash is offline
Last journal entry: Albany Oregon Show
Line Lock
Hurst makes a T shift handle with a button on the side that I use for my line lock. In the past I rigged a radial arm switch on the clutch arm to engage the line lock when I pushed the clutch down and disengage when I let the clutch up. Since I had no reason to apply the break when I was moving it had no affect when shifting on the track. A second switch turned the line lock off when I was not on the strip. The clutch switch worked fair to okay but the T handle is simple and easy.
Bob
