line lock - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2006, 07:26 PM
line lock
I am an old guy with a 4-speed 350 56 chev.I am trying to learn how to drag race it.I ran it last friday night and sometimes it would roll and cause a redlight.I bought a tci line lock which I haveny received yet.Somebody please explain to me how to work the gas,clutch and the line lock at the same time. thanks proge
Old 10-09-2006, 07:41 PM
poncho62's Avatar
Wiki Edits: 5
Is your dragstrip on a hill?....It shouldn't roll, unless your clutch is grabbing a bit, Check this first.
The linelock holds the front brakes on as long as you are holding the button down....As soon as you release it, they release the brakes. You will need to peactice a bit to release just as you are hitting the gas and releasing the clutch.
Old 10-09-2006, 08:36 PM
Install line lock on front tires, when you stage, hit brake pedal and hit button on line lock, this should hold car still, then you can work gas pedal and clutch separately,don't get in any hurry cause you got a second and a half till green comes on,when you dump clutch(on last yellow bulb), let off button.
Also I think you may be able to hold button down and still hit brake and it will hold. You can experiment on that.
Been many moons since I ran a four speed, on the strip, Glide w/transbrake is the way to go, less breakage.
Old 10-10-2006, 04:44 PM
I will try it when I get it thank you very much proge
Old 10-15-2006, 10:19 AM
machinist & fabricator
have seen a few line lock installs....
DONT FORGET YOUR PIPE TO TUBE FITTING @ THE TOP!!!!!
Old 10-17-2006, 12:25 PM
Last journal entry: Albany Oregon Show
Line Lock
Hurst makes a T shift handle with a button on the side that I use for my line lock. In the past I rigged a radial arm switch on the clutch arm to engage the line lock when I pushed the clutch down and disengage when I let the clutch up. Since I had no reason to apply the break when I was moving it had no affect when shifting on the track. A second switch turned the line lock off when I was not on the strip. The clutch switch worked fair to okay but the T handle is simple and easy.
Bob
Old 10-17-2006, 03:04 PM
Bob
if the line lock disengages when you let off the clutch... how did you do a burnout?
Old 10-17-2006, 03:20 PM
Burn out
Second trigger on the counsel for line lock. This was in the seventies before I found the T handle switch and I was just out of high school and afraid of the car. I needed both hands on the wheel, eyeballs like saucers and a knot in my gut. I added the radial switch to my post because I thought it was an odd and unusual way of taking care of the problem. At this point the T handle is much better.
Bob
Another problem with the clutch trigger I felt for some reason the line lock did not let go immediately when I launched. It was one of those things I couldn't prove but my 60 was better when I did not use it.
Line lock on rear wheel Bandit1980 Suspension - Brakes - Steering 13 03-12-2010 06:53 AM
89 dodge dakota anti lock and brake light on notmrgoodwrench Suspension - Brakes - Steering 14 06-05-2006 09:41 PM
brake line lock as security measure? blndweasel Suspension - Brakes - Steering 4 04-05-2005 07:33 PM
What exactly is a line lock? frankenvette Transmission - Rearend 39 03-16-2005 07:03 AM
Fuel Injection Fuel Line Plumbing william27103 Engine 0 06-08-2004 11:31 PM
