line lock activation switch location - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2005, 10:31 PM
mrtimstik
Where do you all have your line lock activation button located??? Shifter, Loose under seat, Heck where ever? Please give me a clue where is the most common place to have it be the handiest for a casual racer. And please some tips on exactly how to use it at the track. Thanks alot guys.
Old 09-14-2005, 11:59 PM
AngliaBob's Avatar
It just takes time and money
Last journal entry: Specifications
Mrtimstik,
My line lock button is on top of the shiftknob.
As far as technique, I depress the brake pedal as hard as I can, and activate the line lock. Give it gas until you are at desired launch RPM, and hit the button.
Good Luck,
Bob
Old 09-15-2005, 10:11 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
Line lock should be located on the shifter. An optional knob with button can be purchased.
It is used in the burn out box, not to launch your car, that's what a tranny brake is for. I have 4" wide tires on the front and 11" slicks on the rear. If I used my linelock to launch. I would push myself right through the lights.
The line lock is installed on the front brake lines. You get in the burn out box and use the linelock to lock up the front brakes. It saves your rear brakes from doing brake stands.
Old 09-15-2005, 10:58 AM
larryblack's Avatar
Certified Lead Foot
As you are going to use it OCCASIONALLY, I suggest you put an arming switch in series with it. That is a switch under the dash, in the console or glove box. That way the line lock ONLY operates when you really need it.
The button should be on the shifter easily operated by your thumb or index finger.
Before trans-brakes and skinny tires, most would push hard on the brake pedal, push the button and then load the converter and chassis some. Running a street car, you should be able to do it this way.
IF you use skinny tires and wide slicks, a trans brake is the ONLY way to launch. Unless you have a stick.
Old 09-17-2005, 12:13 PM
Tazz
mine are located
on the shifter.
Tazz
I want to install an underdash ignition kill switch in my 67 nova...can you help? batman09 Electrical 40 05-15-2005 10:47 PM
What exactly is a line lock? frankenvette Transmission - Rearend 39 03-16-2005 07:03 AM
What can a line lock do? elukas General Rodding Tech 7 01-13-2004 07:52 PM
Ford spring lock fuel line coupling question dirtlmfan Engine 5 07-09-2003 11:52 AM
LINE LOCK BIGBLOCKSTANG Hotrodders' Lounge 7 11-06-2002 12:10 PM
