Line lock install - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2007, 12:10 PM
red_rider52's Avatar
DriveItLikeItsSupostToBeD riven
Line lock install
Hello I got myself a B&M line lock and was wondering if I would be able to mount it before the differential pressure block? In the instructions it shows to mount it after but that would require me to bending the original break lines? would it still work if mounted before the pressure block thank!
Old 05-07-2007, 05:11 AM
MrPhotographer06's Avatar
Army Strong
Last wiki edit: How to remove a VW Type I body
Last journal entry: well once again
[nothing to help you..sorry ]
but is the pressure block where the 2 brake lines screw into the little block and 2 more come out the back?
Old 05-07-2007, 06:01 AM
The 2 lines go into it from the master cylinder and 3 lines come out of it. 2 to the front breaks and 1 to the rear
Old 05-07-2007, 10:07 AM
DOUBLEDICK's Avatar
I have mine between the master and the separator block and it works great.I love doing burn outs at car shows
Old 05-07-2007, 12:27 PM
Army Strong
thanks i thought that was right =P
Old 05-07-2007, 05:01 PM
Thanks Doubledick I can't see what would be the difference haven't it before or after but just thought i would ask in case I missing something.
Line lock on rear wheel Bandit1980 Suspension - Brakes - Steering 13 03-12-2010 05:53 AM
leaky fuel line? jackflash Engine 1 08-15-2005 03:16 PM
brake line update 61bone Suspension - Brakes - Steering 5 07-07-2005 04:42 AM
brake line lock as security measure? blndweasel Suspension - Brakes - Steering 4 04-05-2005 06:33 PM
What exactly is a line lock? frankenvette Transmission - Rearend 39 03-16-2005 06:03 AM
