line lock onna hotrod - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2006, 01:24 AM
machinist & fabricator
car: 30 olds
brakes : mid 70's GM stock 11"disc front, drum rear (10 bolt)
master cylinder is mounted under the floor, risidual valves have been installed.
it has proportioning knob valve installed for the rear brakes.
if i was to install a line lock for the front brakes, should i do it before or after the residual valve?
does it matter?
why?
thanks!!!
B
Old 09-08-2006, 07:16 AM
65 Imp SS's Avatar
Here is install instructions for a hurst line loc.
http://go.mrgasket.com/pdf/RollControl[1].pdf
89 dodge dakota anti lock and brake light on notmrgoodwrench Suspension - Brakes - Steering 14 06-05-2006 08:41 PM
brake line plumbing..help RodFather Suspension - Brakes - Steering 8 07-11-2005 07:06 AM
Fuel Line Q S10Fan Engine 1 07-26-2004 05:11 AM
Ford spring lock fuel line coupling question dirtlmfan Engine 5 07-09-2003 10:52 AM
LINE LOCK BIGBLOCKSTANG Hotrodders' Lounge 7 11-06-2002 11:10 AM
