Line Lock Will Not Hold - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2011, 01:59 PM
We are working on a '73 Duster put together primarily for drag racing. The line lock is set up directly off the m/c without a distribution block. The lock "clicks" when activated, holds slightly for a second or so, but will not hold hard. Any suggestions? thanks!
Old 10-09-2011, 02:47 PM
WDCreech's Avatar
Grumpy Old Goat Herder
Did you pump the brakes up tight before activating the line lock?
Old 10-09-2011, 03:07 PM
Sure did. Just doesn't hold
Old 10-09-2011, 04:21 PM
WDCreech's Avatar
I would call/email the manufacturer of the line lock and see if they can shed some light on the problem.
Old 10-10-2011, 09:16 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Are the front tires rolling or sliding? I ask because most cars will slide the fronts at some point providing there's traction for the rears.
If the tires are rolling, either the lock isn't holding pressure- or the master isn't supplying enough pressure to the calipers in the first place, or the front brakes are inadequate for some other reason- worn pads, glazed rotors, oil or grease contamination, etc.
Old 11-06-2011, 02:55 AM
fstfish66's Avatar
mopar or no car
get a brake line pressure gauge master power brake sells them, maybe even one of the mail order places,,,see how much line pressure you have,at the caliper
Line Lock 71 c-10 Suspension - Brakes - Steering 5 04-26-2007 07:00 AM
line lock proge Hotrodding Basics 7 10-17-2006 03:20 PM
What exactly is a line lock? frankenvette Transmission - Rearend 39 03-16-2005 07:03 AM
What can a line lock do? elukas General Rodding Tech 7 01-13-2004 07:52 PM
LINE LOCK BIGBLOCKSTANG Hotrodders' Lounge 7 11-06-2002 12:10 PM
