Line-O-Tronics two post car hoist - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-11-2009, 07:16 AM
line-o-tronics model 315 2 post car lift
I have had my lift for several years and I can not get any information on it,the company is out of business my lift is model # 315 serial # 2003 the person I bought it from rebuilt the cylinder when it started to leak he said he had to cut the end off rebuild then weld it back back on,my lift does not give the capicity on it .
  #17 (permalink)
Old 11-11-2009, 11:17 AM
Jay
Thanks for the reply! I kind of figured that the company is out of business. I couldn't find anything on the internet. This lift belongs to a friend. I told him that I may be able to put new o-rings/seals if I could get it apart and take some measurements. Thanks again. J
  #18 (permalink)
Old 11-11-2009, 03:16 PM
Although its not unheard of, its really rare to find a cylinder that has to be cut apart and welded back together for a rebuild. If a person isn't familiar with the various ways of building cylinders, its real easy to think a cylinder whose rod gland is held in with a lock wire can't be disassembled, when in truth its one of the easiest types to disassemble. I've repaired cylinders off a couple different unknown brand post type lifts, and both of them had lock wire cylinders. The only fully welded cylinders I've encountered were on military equipment where the entire cylinder was to be replaced as a unit rather than rebuilding.
A lock wire cylinder will have a slot about 3/4 to 1" long in the cylinder barrel a half inch or so down from the end of the barrel on the rod end. To remove the lock you rotate the head gland with a spanner wrench, pipe wrench, or whatever until the end of the wire shows up in the slot. The pry up slightly on the end of the wire and rotate the gland in the proper direction to wind it out thru the hole. To reassemble, locate the hole in the wire slot, hook the wire into the hole, and rotate the gland to wind the wire back into place.
  #19 (permalink)
Old 11-11-2009, 07:56 PM
Jay
Thanks, for the information Tubetek, I like that method better than cutting and welding. I didn't go by the shop today, but I will stop in tomorrow to see if that cylinder has the slot you speak of. J
  #20 (permalink)
Old 12-01-2009, 02:28 PM
Jay
Need seal for 315 line-o-tronics lift
Anyone know where I may find a new seal for this cylinder. I have taken it apart and the seal has no identifing marks. Thanks, Jay
