Linear Actuator control? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2008, 02:51 PM
FREE TRAMAMPOLINE!!!
Hi guys,
Been a while since ive been here, sorry about that.
Anyway, Can anyone tell me if you can limit the stroke on a linear actuator??
I want to use one to control the headlamp covers on my 70 cougar instead of the vacuum set-up but dont really have any idea how to go about it. ie: controlling the actuator through the headlamp switch on/off and having the actuator move the correct amount.
Any advice
Cheers
Nick
Old 05-30-2008, 04:07 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
McMaster-Carr carries those things and some of them might be just what you need..They come in several different varieties..Some of them I think have an adjustable travel range..would bear some more checking..
Sam
Old 05-30-2008, 07:47 PM
powerrodsmike's Avatar
Wiki Edits: 161
Some have limit switches, some don't ..You can also make your linkage adjustable and utilize the full stroke of whatever actuator you use.
Some places that sell smaller actuators are , Firgelli automotive, dakota digital, autoloc and IIRC even speedway sells them.
later, mikey
BE different....ACT normal.
Old 05-31-2008, 12:39 AM
ah so they have limit switches!! that makes a whole lot of sense. Ill have a look a those suppliers.
cheers.
Nick
Old 05-31-2008, 07:37 AM
Wiki Edits: 161
Here are links to a couple....
http://www.thehoffmangroup.com/autol...inearactuators
http://www.firgelliauto.com/
Mikey
Old 05-31-2008, 07:50 AM
So where it says 'Limit switches, Non movable' does that mean it will only stop at the start and end of the stroke?
If thats the case I need one with 'Movable Limit switches' yes??
Old 05-31-2008, 07:55 AM
Wiki Edits: 161
They are exactly as the name implies.
Mikey
Old 05-31-2008, 07:57 AM
In which case the ones on the Hoffman group website seem perfect as you can adjust the stroke and as a plus they even show a wiring diagram!!!
Expensive but hey, custom work is I suppose
Many thanks for your time and help.
Nick
Remote linear actuator wiring. carlmb Electrical 3 04-24-2008 09:02 AM
Linear Actuators Job~Rated Electrical 11 01-03-2008 03:20 PM
Variable Rate Springs vs Linear Rate JohnTN Suspension - Brakes - Steering 6 09-13-2007 07:10 PM
Linear Actuators Silver_Camaro Electrical 2 07-02-2003 02:10 AM
