Linear Actuator Trunk Lift Kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2013, 09:39 PM
Butch60's Avatar
Last wiki edit: Sourcing grilles Last photo:
Do anyone know where I can get the aluminum arms for the linear actuator trunk lift . My trunk jammed and stripped the splines out of the aluminum arm. I called Carolina Custom ,they said they arms would not work because the shaft diameter was 3/4" where mind is 5/8". I was told my unit is one of the early models. I'm just trying to keep for buying a complete unit ,all the other pieces are fine.
Any help is appreciated
Old 02-12-2013, 12:47 PM
vinniekq2's Avatar
try KMS they have a tool shop and custom parts for old hotrods.I dont know much about them ,just they seem to find things if needed
Old 02-12-2013, 07:39 PM
Butch60's Avatar
Thanks for your input ,I only see tools on their website will also give them a call.
Old 02-12-2013, 08:03 PM
vinniekq2's Avatar
they have a hot rod division.I could find phone numbers for you?
Old 02-12-2013, 08:07 PM
Butch60's Avatar
That will be great , thanks again.
Old 02-12-2013, 08:17 PM
vinniekq2's Avatar
Address: 110 Woolridge St, Coquitlam, BC V3K 5V4
Phone604) 522-5599
Old 03-10-2013, 07:02 PM
Butch60's Avatar
Trunk Lift Kit
I worked out my problem with the trunk lift kit arms. I was able to find a 5/8" spline shaft and collar for about $26 at Dune Buggy Parts, Sand Rail and Volkswagen Parts | appletreeauto.com. Also I brought a piece of 1/2" x 3/4" steel bar at Metal Depot: New, Useable, Surplus Metals and Industrial Supplies for $13. Everything works just fine now. For those of you that are in the same situation as I here are some pictures .
Name:	power trunk arms 004.JPG
ID:	72189   Click image for larger version
Name:	power trunk arms 006.JPG
ID:	72190   Click image for larger version
Name:	power trunk arms 008.JPG
ID:	72191   Click image for larger version
ID:	72192   Click image for larger version
linear actuator override 71corvette Electrical 12 08-11-2008 10:58 PM
linear actuator dimentions for trunk lid Mrwood General Rodding Tech 2 08-08-2008 06:56 PM
Linear Actuator control? nick69 Electrical 7 05-31-2008 08:57 AM
Remote linear actuator wiring. carlmb Electrical 3 04-24-2008 10:02 AM
