lines are off on ss hood for 68 chevelle - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2011, 08:20 PM
Sarge
I switched out the regular hood on my 68 for an SS hood. Picked up the "69" hinges to swap out this hood but the drivers side rear is raised about 1/8 to 1/4 of an inch and the front in the middle is raised about the same! I have a really hard time closing the hood, you have to slam it and even after loosening the spring a bit it is really tight and doesnt line up with the rest of the front. Do I need "69" springs for those hinges? The salesman said if my springs from the "68" were in good shape I could swap them out but some guy told me I need "69" springs.
Sarge
sgt4e@verizon.net
Old 06-04-2011, 05:55 AM
deadbodyman's Avatar
Wiki Edits: 11
it just needs to be adjusted....take the latch/or striker out first...lower the rear hinge and adjust the hood so its sitting on the rubber adjusters...when its sitting where you want it put the latch/or striker back in and adjust that
69 chevelle stock hood ss396si Hotrodding Basics 2 04-26-2011 06:11 AM
Hood pins on a 72 Chevelle phorce1 Body - Exterior 1 05-26-2006 09:05 PM
chevelle brake lines?? TASHAN Suspension - Brakes - Steering 2 01-13-2006 10:39 PM
Chevelle hood release Q skeeveman Body - Exterior 0 11-11-2005 03:23 PM
Chevelle hood Scrooge Body - Exterior 3 07-29-2003 04:00 PM
