We're winning the case!
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 03-11-2009, 03:13 PM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
OneMoreTime's barnstar
Wiki editor
Wiki Edits: 3
Link to Rust Wiki Dealing with Rust
In order to provide a fast look up to the rust wiki I am posting the link here: http://www.crankshaftcoalition.com/wiki/Rust Lots of information on what rust really is and various ways of dealing with it.
I am also making this a read me at the top of the forum to make it easily accessible to the people needing it.
Sam
I would rather make it work than make it popular..And if it does not work it will not be popular..
Old 03-11-2009, 06:31 PM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
willys36@aol.com's barnstar
Wiki editor
Last wiki edit: Fiberglassing
Wiki Edits: 20
That takes all the fun out of our rants and raves!
Old 04-20-2009, 01:23 PM
pompano100 pompano100 is offline
getting rid of rust
one easy solution to ridding rust is using zero rust prep. this is a non acid phosphatizing powder mixed with water and sprayed on with water sprayer or power washer. zero rust prep will disolve light rust into a dust. you should hand tool any scaling or bubbling on the metal. depending on how tight the rust is you wont need to sandblast. the zero rust prep will then condition the metal to a ph6 which is nearly neutral and perfect for painting, this will also provide a 30 day window unless of course the surface is grounded, when you see the light dust if you want to remove it, just use air or a paper towel. then when the prep step is dry apply zero rust rust inhibitor and you will be protected against rust for many years, **************
is the website of the distributor who happens to be me. if i can help let me know.
Last edited by OneMoreTime : 04-20-2009 at 01:37 PM. Reason: Advertising. Please see: commercial posting guidelines.
Old 10-25-2009, 09:12 PM
boosting27 boosting27 is offline
ive got it
if its not sandable cut it out if its not metal its not a rod its a no brainier bondos makes a mess's also lead it i plan to get my shop going good enough i plan to teach the right way to people and pay then instead off uti turing out people who make mess's for people like me there post on that little bit for conversational peace
Old 10-26-2009, 06:49 AM
Wiki editor
Wiki Edits: 20
Use some punctuation. Your post is very hard to decipher. Also a pass through the spell checker wouldn't hurt.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Link to Rust Wiki Dealing with Rust"
secrets of surface rust removal revealed Randy Ferguson Body - Exterior 147 05-08-2009 05:16 PM
phosphoric acid based rust dissolver rlackey Body - Exterior 15 01-05-2006 07:07 PM
RUST..What are the acceptable permanent ways to get rid of it? Rocket1 Body - Exterior 174 09-28-2005 07:37 PM
Dealing with surface rust PrimeMover Body - Exterior 1 09-29-2003 10:07 AM
Phosphoric Acid + Prevention of flash/surface rust unstable Body - Exterior 3 07-21-2003 07:36 PM
