Linkage - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2008, 07:12 PM
Linkage
I`am trying to complete the throttle and auto kickdown linkage. I have a edlebrock carb and intake. It is a 1977 Camaro Type LT. The throttle linkage and the trans kick down have square plastic push in style that hold them into a bracket. The throttle holder is smaller then the kick down. I can not find anything that will work. Anyone have a idea that can help me. Campy
Old 01-09-2008, 07:43 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Are you looking for a bracket or cables?
Old 01-09-2008, 09:02 PM
edlebrock offers all kinds of linkage kits for the carbs, your local advance auto or speed shop should be able to get what you need. sam-missle
Old 01-12-2008, 04:14 PM
77 camaro bracket
Thanks Guys i found the bracket on jegs.com for my car. #8030 will work just fine.
David.
Progressive Linkage On Blower Carbs Setup? 5-7heaven Engine 6 10-07-2007 10:30 AM
tunnel ram linkage pal Engine 2 03-19-2007 07:34 AM
Clutch linkage problems-Centerforce??? baddbob Transmission - Rearend 1 03-09-2007 08:50 AM
Three speed trans linkage david puga Transmission - Rearend 2 09-14-2005 07:15 PM
clutch linkage!!? chevyelc81 Transmission - Rearend 11 08-01-2002 06:46 AM
