linkage adjustment, how too - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2013, 09:57 PM
Last journal entry: On the Road again
got 700r4 in 48 F1, the steering column is 33inch long with shift. I got a Lokar
linkage kit. The first time I cut the rod it was to short. What is a good way to set this up? The second attempt with a longer rod got all the gears but the lower ones go off the shift indicator. I was going to start the third time by setting the rod size at nuetral. Must be a easier way??????
Old 11-14-2013, 01:22 AM
lokar instruction sheet
Ok,,,color me dumb ****---I went to lokar web and got the instruction sheet for the exact column shift linkage installation instructions. Soo hey i didn't know they had such a service!! Now I know...
1958 Cast iron powerglide linkage adjustment? lilrobo Transmission - Rearend 2 01-25-2013 04:05 AM
700r4 linkage adjustment cableman Transmission - Rearend 1 03-05-2012 06:45 AM
Backdrive linkage adjustment on 1981 camaro toddiyaayas Transmission - Rearend 2 05-15-2007 04:22 AM
'88 Corvette 4+3 linkage adjustment TooSlow Transmission - Rearend 2 07-25-2005 06:46 PM
Turbo 350 linkage adjustment dpj450 Transmission - Rearend 1 10-24-2001 06:35 PM
