Linkage Bushings
I'm having trouble locating the correct shifter bushings for a 4-speed Muncie in my 64 Nova. I bought some Mr Gasket #11 steel bushings, but their too big. I measured the hole in the linkage arm to be 0.380". The new steel bushings measure 0.5" O.D. It's been suggested that I inrease the diameter of the hole but that seems a bit radical to me. The local speed shop said that if the shifter was from the factory, they wouldn't be able to get the correct bushings. I called the Nova supply houses & they were good enough to measure theirs for me; of course they measure 0.50". Any ideas?
Also, the old rubber that is molded to the link arm has to be removed when using the steel bushings correct? Thanks for any/all help. |
Go down to your local hardware store (not HD, or Lowes) like an ACE. Look for some nylon bushings in the nuts & bolts section. You don't need steel ones for normal driving
| tunnel ram linkage | pal | Engine | 2 | 03-19-2007 07:34 AM |
| Redoing 74 Nova Bushings - Initial Planning | topdogger | Suspension - Brakes - Steering | 8 | 11-13-2006 10:28 AM |
| Mustang-II rack & pinion mounting bushings?? | NASCAR314 | Suspension - Brakes - Steering | 4 | 02-08-2005 12:53 PM |
| Ford 3 on the tree linkage | Disturbed1 | Transmission - Rearend | 4 | 12-03-2003 01:16 AM |
| Urethane Bushings - Yes or No?? | Jim Weeks | Suspension - Brakes - Steering | 5 | 05-01-2002 08:12 AM |
