liquidation of illiteracy 1 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2005, 12:57 AM
1300
I have unexpectedly found out, that I know nothing about body mods, even about they types. Except for chopping.
Somebody will lead liquidation of illiteracy?
Old 12-17-2005, 01:00 AM
1300
Liquidation of illiteracy 2
Yea, and i'm absolutely lost in paint world.
Somebody,please,Explain a difference between various kinds of paints (IE candy,pearl,etc)
Old 12-17-2005, 08:20 AM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
READ EVERY POST ON THIS FORUM.
Seriously, Order a House of Kolor Technical Manual. That has most all of the information on what,how,kind of your asking.
Then,get an Alsa Maunal.
That has the really weird,cool paint systems.
Old 12-17-2005, 09:32 AM
"Top chopping" Lowering the roof by shortening the posts.
"Body sectioning" or usually simply "sectioning" is lowering the body by cutting and removing a portion of it horizontally, like a top chop to the body it's self, usually right thru the middle of the doors, quarters, and fenders HORIZONTALLY.
"Channeling" is when you cut the floor out and lower the body over the frame.
"Frenching" is moulding in or "Smoothing" anything. "Frenched" headlamps are where you weld in the head lamp ring so the head lamp glass is all you see. "Frenching" an ant is removing the nut in some way.
"Tunneling" is where you Tunnel something in using tubing or a home made "tunnel" to tuck something back into the body. "Tunneled" antenna is where you would use exhaust tubing or similar and weld a washer on the bottom and weld the tube into the car so that the antenna is sitting in a tunnel. (click here for how to)
"Tunneling" headlamps or taillamps is the same thing, "sinking" them into the body.
"Shaving" is simply removing and welding or moulding off the holes. You would "Shave" emblems, bolts on a bumper, etc.
These and other terms can be regional as well. Someone in New York may use completely different terms but these would be understood.
Old 12-18-2005, 12:28 AM
1300
Uh,thanks.
Old 12-19-2005, 12:58 PM
tab's Avatar
tab tab is offline
paint
You don't need to know about all those different types of paint. You only need to know about one color, Black
Old 12-20-2005, 12:25 AM
1300
Shoot any guy who says:"...black..."!!!
