Listings - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2013, 10:20 AM
Listings
So I'm wrapping up the bottom of my bench seat and all I have left is the listings and the j channels. On the listings, what should I use for the wire? Plastic welt cord, actual wire or the fiber welt chord? Then on the j channel, is it ok to reuse the j channel I took off the old cover? Thanks so much for the help!
Old 07-15-2013, 12:09 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Yes, it's O.K. to re-use the "J" channel. You can use anything in the listings that will hold the hog rings and be relatively flexible if you're turning a corner. Any of the things you mentioned are fine.
Old 08-05-2013, 11:05 AM
I'm doing a back seat of a 67 Cadillac right now, and I replaced the old listing wires with wire coat hangers.
Old 08-07-2013, 02:17 PM
That's what I plan to use. How do you figure out where exactly to sew the listing on? Do you sew it at the end of your fabric at the hem or a little up from that?
Houdini
Old 08-07-2013, 09:11 PM
Wiki Edits: 22
You sew it on where it was sewed on the original seat cover.
Old 08-12-2013, 07:55 PM
If only I had the original seat covers! I'm having to make my own patterns. I imagine, I'll just have to measure carefully after I sew on the boxing and see where they'll go.
Old 08-13-2013, 08:23 AM
Wiki Edits: 22
Listings are pretty self explanatory. Check after the boxings are sewn on and then adjust the boxings or the listings to get a snug fit.
