A little "clockwork" - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2009, 01:07 AM
Modern_twist's Avatar
new pontiac owner
Last journal entry: start of teardown
I want to convert my 40 pontiac over to 12 volt system i want the original dash clock to work though so can I just add a resistor in the line to keep it six volts? or what should i do?
Name:	right interior.jpg
Old 09-09-2009, 03:36 AM
Rustydawg's Avatar
Cruzin w/Elvis in Bigfoots UFO
The only mechanical car clocks that I have experience with use a small solenoid to wind the clock spring back up; when it winds down to a certain point a set of contacts close together, which energizes the soleniod to wind it up again.
If yours is like this I would be concerned about the contacts wearing faster because of the higher current that the 12V will drive through the coil. You could experiment with running it through a tail lamp bulb or something similar.
You could wire a resistor in series to limit the current, I would start with something like a 10 ohm resistor. Get a resistor with 1 Watt or more power rating for durability and to have thicker leads to work with.
Old 09-09-2009, 09:05 AM
302 Z28's Avatar
There are firms that market resistors specifically for this purpose. They are sized appropriately to prevent over heating.
Vince
