A little help with my Model AA Truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2005, 10:27 PM
I'm putting my 327 in a model AA truck and will use it on my farm. I want to know what frodnt suspention to use if I'm going to be carrying around 1000lbs of product. Is a Mustang II Suspention going to be strong enough? I'll use a rear end from a Chevy 3 quarter or half ton. Thanks.
Old 05-17-2005, 11:28 PM
Wiki Edits: 49
If it's an AA truck I'd just rebuild the stock suspension, it's certainly heavy duty enough. Might change to disk brakes though. Although I am an advocate of the Mustang II IFS for your application I really think you need something a little more robust.
Old 05-17-2005, 11:33 PM
poncho62's Avatar
Wiki Edits: 5
You may want to transplant your "AA" truck body to a whole later model truck frame..........Best of both worlds, neat old truck and all the modern conveniences....like good brakes.
Old 05-19-2005, 07:17 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
My brother has a '29 AA. Best bet for you would be leave it alone (fix it up) and buy a 70's to 90's truck. At least that's what I'd do. That's a lot of tonnage there.
In a while, Chet.
Old 05-21-2005, 09:15 AM
if I used the stock axle, and went with disc brakes,what would I use for spindles? I'm thinking maybe sraight axle drum setup from early 60's ford or chev and then using a disc conversion. thanks for the input.
Old 05-21-2005, 01:39 PM
tbirdscott's Avatar
stuff'n things'n whatnot
Another idea would be to go with a FORD engine! buit thats just me...
Where in b.c. are you located?
Old 05-22-2005, 12:41 PM
I'm using a 327 because I have it in my shop. It's out of my 68 PU which was the second truck I owned . also sb chevys are supposed to be easier to fit in a model A. Ilive in the okanogan.
Old Skool Truck Questions Riot Racing Hotrodding Basics 33 03-17-2011 02:04 AM
Seems Best way to Buy a 454 BB is to Buy a Truck Auto-Part Engine 3 11-15-2003 05:23 AM
What car (make and model) can be use to place a Model A body? Fortingo General Rodding Tech 7 05-10-2003 04:25 PM
confusing question about cars and their weight stonedchihuahua General Rodding Tech 14 03-27-2003 04:00 PM
late model bed on classic truck Lightspeed Body - Exterior 6 09-26-2002 12:32 AM
