a little problem with a support on a 57 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2007, 02:20 PM
I NEED HELP!! I have a 57 bel air 4drhdtp and I need info on the center brace that is specific to that model. I cant find anything and know one repop's these brace ends. I'm at my wits end here and dont know what to do. Thes ones on the car are so rusted and badly mutilated from a bad repair that there is know way to go by them....WHAT DO I DO!! Ive been to a few of these online forums and everyones a big help so far but nothing solid. does anyone have one, no where i can get them, happen to have a 4dr hdtp laying around that their parting out, ,,,,know of a magic sheet metal genie that can grant me my 3 restoration wishes???
Old 09-17-2007, 05:05 PM
Will I ever get it done?
Last journal entry: Hood
http://www.danchuk.com/12_03_center_floor_braces.html
Old 09-17-2007, 07:19 PM
Cape Cod Bob's Avatar
ask and ye shall recieve
gotta love these forums
Old 09-17-2007, 07:20 PM
unfortunatly danchuk doesnt have it...cars doesnt have it either. At this time no one makes this brace that is specific for the 4dr hdtp.....in lies my problem
Old 09-17-2007, 07:23 PM
yep...thats not it. It is for the other models but the 4dr hdtp is totally different. Its wider and is mounted further back than the rest so it ends up under the center pillar...heres a pic from another member...
Old 09-17-2007, 08:59 PM
I never picked up on the fact that the 4 door ht has a special brace. I was always looking for 2 door parts. I went out to Sherman and they specifically say they don't have the 4dr ht brace. I think the parts C&P sells is Sherman, so they probably won't have it. However, it was my experience that both Danchuks and C&P's were very helpful folks. Have you called them?
Old 09-18-2007, 07:29 PM
yep trust me its not made. If i could get my hands on one at least to use as a patern id be set. This is whats holding me back right now
Old 09-19-2007, 05:20 PM
no one here have any ideas???!!!
Old 09-19-2007, 05:56 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Unless it's a real rusty car, most likely just the outboard ends are bad?
I looked at the pic real good and it looks easy to make by welding pieces and a little forming. I used to make 60-66 chev truck floor braces before they were repo'd. 16 ga works real good for braces.
Just using the pic and going by your floor shapes, you should be able to make your own pattern.
Old 09-19-2007, 05:57 PM
powerrodsmike's Avatar
Wiki Edits: 161
Hi I'm no one and I have some ideas...
Is this a restoration?
Can you make a set of patterns off the good side and flip the pattern so you can make a mirror part?
Although that original brace is stamped, you could duplicate it out of flat sheetmetal and weld the corners that you couldn't bend.
Could you make a new simple fabricated brace that does both sides, then they'd match, if that is what you are trying to accomplish.
Later, mikey
BE different....ACT normal.
Old 09-19-2007, 05:58 PM
Wiki Edits: 161
Not trying to be a copycat..I was making my reply when F&J was making his...
Mikey
Old 09-19-2007, 07:27 PM
problem is there isnt any good side...there both shot and have been hacked into. Im trying to get as close to the orignal as possible but i might have to take a shot at making them.
small blcok chevy! The ultimate starter problem! S.O.S. sugar ray Engine 11 07-19-2007 08:07 PM
I'm having a primer adhesion problem on one door Ripped Body - Exterior 10 06-08-2007 12:45 PM
96 Plymouth Voyager spark problem? baddbob Electrical 12 05-19-2007 03:44 PM
available engines in 57 GMC Beastmotorcycle Introduce Yourself 1 01-05-2005 10:29 PM
Puzzling temperature problem on the hemi solved Centerline Engine 2 11-26-2004 03:48 PM
