A little shameless self-promotion. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2005, 09:04 PM
Bad Rat 414's Avatar
www.bigblock67chevelle.co m
I've updated my website. It has a few pictures of my failed engine parts.
www.bigblock67chevelle.com
Old 10-16-2005, 10:07 PM
redlightning's Avatar
Good pictures,Thanks for sharing.
Old 10-16-2005, 11:10 PM
97Z28's Avatar
NTI Grad.
looks good man....
Old 10-17-2005, 02:11 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
That looks almost as bad as my 1600 mile 350 that I put in my '93 Silverado. The previous person that rebuilt it put it together dirty. Meaning he did not flush out all of the oil galleys. Three main bearings were shot that were down to solid copper, front and real cam bearings shot, a couple of rod bearings also had copper showing. The crank now has to be turned. The was an area in one cylinder that looked like it had water sitting in it for an extended length of time and scored the wall. so another bore is in the works. It is already .030 over so it goes .040 or .060. And the valve guides in the heads are also shot so rework is in order on those also. This all came about from me trusting others. It will be better than new when done though
BTW...keep us updated on the rebuild. Looking forward to hearing the Rat run!!!!
Old 10-17-2005, 03:19 PM
johnsongrass1's Avatar
Race it, Don't rice it!
You bearings indicate a timing/detonation problem. Or a lean condition causing high cylinder pressure that beat the copper off the bearing. Verify your TDC mark is acurrate with a TDC stop and also double check you cam wasn't walking and changing your timing. You can look for signs at the cam gear.
Old 10-17-2005, 05:47 PM
dawg's Avatar
NAVY VETERAN
turn down the music! plz heheheh
Old 10-17-2005, 07:13 PM
Like I said I had massive blowby because of low compersion due to the ring gap. The cylnders were soaked with fuel so there was no lean conditon. I know the cam was not walking because I was runing a cam button.
Old 10-18-2005, 09:38 AM
And your poor oil control lowers the effective octane level leading to the bearing being scored.
I'm just trying to help you. That's all.
Old 10-18-2005, 09:56 AM
I understand that your tring to help, but I also had grit in the oil from the blanceing job. I believe that's what chewed up the bearings. It also scared the crank.
Old 10-18-2005, 11:47 AM
Weimer's Avatar
Kenneth Howard hates you...
Last journal entry: door pics smaller
You know its a bad rebuild when the crank gets scared...I hope that the cam doesn't have any fears, then you will definately be screwed. LOL
Later,
WEIMER
Old 10-18-2005, 11:53 AM
Yeah, well it frightened the s*it out of the pistons too.
Old 10-18-2005, 03:13 PM
cool
Old 10-18-2005, 06:35 PM
coldknock's Avatar
I hope you didn't scare 'em as bad as I did mine.
Larry
Old 10-18-2005, 06:38 PM
Not this time but I've done worse than that in the past. I've had piston pieces no bigger than a quarter.
Shameless Promotion '35 Sedan Delivery Hotrodders' Lounge 0 07-09-2004 07:52 AM
Shameless SPAM...but I need a T-5 drgnwgn289 Transmission - Rearend 6 10-15-2003 11:49 PM
