The little things you wind up making.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2010, 11:07 AM
Wiki Edits: 49
Just working on some little odds and ends. Needed something to hold up the trunk when its open. I could have just used a rod or gas shocks but decided to do something a little different so I made up a couple "over center" hinges similar to what they use on NASCAR hoods to hold it open.
They fold towards the rear and were made of 1/8" steel bent up with a hammer and vice.
Finished product.
Old 10-15-2010, 11:55 AM
daoldbuick's Avatar
Very cool! And you can plate, paint or polish to suite your taste. Cool
Old 10-15-2010, 07:40 PM
Cape Cod Bob's Avatar
Great idea. How do you close it? Lift the trunk lid a little and get the hinges moving and then lower it as they come back to center?
Old 10-15-2010, 07:44 PM
poncho62's Avatar
Wiki Edits: 5
Good idea... .......Hope those holes in the boards are not for big whoopa$$ speakers.........
Ontario Rodders
Old 10-16-2010, 07:22 AM
cboy's Avatar
Last journal entry: Finished
This one is going in my "Steal it Now" file. Great ingenuity and design.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 10-16-2010, 08:23 AM
Yep, those are slick.
Old 10-16-2010, 05:12 PM
Wiki Edits: 49
Nope. This car probably won't even have a radio. But....if it did have a radio you'd need speakers that big just to here it.
Exactly.
Old 10-16-2010, 06:33 PM
Centerline,
I think the idea is a great one. My only suggestion would to make a pivot bracket for the lid itself so the hinges do not scrape the paint off the trunk lid when it is opened and closed, like the ones at the fenders.
I think I will file this one away too. I like it!!
Scholman
retired
Old 10-16-2010, 08:47 PM
Wiki Edits: 49
Originally Posted by scholman
...My only suggestion would to make a pivot bracket for the lid itself so the hinges do not scrape the paint off the trunk lid when it is opened and closed, like the ones at the fenders.
Not sure I understand what you're talking about. There are no fenders and the lid hinges clear with plenty of room.
Old 10-17-2010, 06:40 AM
deadbodyman's Avatar
Wiki Edits: 11
Theres another one of your ideas I'm stealing CL...Way Kool..
Old 10-17-2010, 08:13 AM
Wiki Edits: 27
looks good.
I still use a stick when working on the 29 nash, the 36 pontiac sedan uses the stock over center design, much smaller with a spring to keep it locked up. Just lift the lid a little to straighen the hinge then pull each hinge over center and the spring holds it to the down side to lower the deck lid.
Making dies and rollers to bend square tubing cboy Garage - Tools 20 11-05-2012 05:59 PM
why is it the simple things break easiest? matt167 Off-Topic 3 04-09-2010 08:12 PM
Making A Fiberglass Console For The First Time nightrain_rod Interior 4 03-07-2006 01:46 PM
Making Progress or making more work for myself?! Weimer Hotrodders' Lounge 5 02-15-2004 03:11 PM
