Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Little tip on MIG welding and tools used.
  #18 (permalink)
Old 01-24-2012, 10:36 PM
tech69 tech69 is online now
put up or shut up
So do you cut it after EVERY weld? I like to cut the wire but not after every weld. I like to hot tack at times and you can't do that if you're cutting the wire. I will cut it if the wire length isn't what I want, there's a ball of metal on it, or the gas has been stagnent in there for a second.
