Little tip on MIG welding and tools used. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-21-2012, 03:59 PM
put up or shut up
Originally Posted by gow589
I am not saying you can't cut it to get the same result, but with wire clippers one hand you have to reposition. But....With the ground clamp close to the weld, both hands are already in position and the movement of the tip is minimal which keeps more shielded gas in the tip.
Honestly you would be hard pressed to clip it with cutters and go straight to the weld in the short amount of time then cutting it off using a grounding clip next to the weld with both hands already in position. The further you physically move the tip the more shielding that is loss as well.
Very little movement and very little delay is optimum.
I'm not so sure about that. I've come to realize that the gas is in there a lot longer than I originally thought. If I stalled for a minute I used to trigger and cut to generate more gas even if it was already done so perfectly due to gas not in the line, but I soon realized it can sit there for a while and still have good gas.
On the welder I use at work, I once forgot to turn on the gas after turning it off for like 3-5 minutes and my first 3 welds were perfectly clean! Not sure If the welder at my house would do that nor do I want to replicate that scenario again but I think the gas is in there for a bit. If I worried about the gas leaving so soon I'd probably also wire brush off more the carbon crap on the welds between welds but I don't, but that is an option when you're twiddling thumbs letting it cool.
  #17 (permalink)
Old 01-21-2012, 10:59 PM
On the light issue, yep and that is why I just don't like the auto darkening helmets. I have used one of these Accustrike for years and I LOVE it wouldn't weld without it.
http://www.accustrike.com/
  #18 (permalink)
Old 01-24-2012, 09:36 PM
put up or shut up
So do you cut it after EVERY weld? I like to cut the wire but not after every weld. I like to hot tack at times and you can't do that if you're cutting the wire. I will cut it if the wire length isn't what I want, there's a ball of metal on it, or the gas has been stagnent in there for a second.
  #19 (permalink)
Old 01-24-2012, 10:36 PM
I cut it off every weld.
  #20 (permalink)
Old 01-25-2012, 07:27 AM
All of these welds were cut off by striking the clamp; everyone..
It's a mix of thin metal and thick. The last is replacing the ends on 1/2" thick blades for a large bush hog on a large tractor which worked clearing fields all summer
All of this with including the blades with .023 wire:
  #21 (permalink)
Old 01-25-2012, 07:48 AM
Beautiful work.
  #22 (permalink)
Old 01-25-2012, 07:57 AM
Thank You Sir!
  #23 (permalink)
Old 01-25-2012, 08:02 AM
What is this one? I love the looks of it.
  #24 (permalink)
Old 01-25-2012, 08:32 AM
It was a display I made a couple years ago:
  #25 (permalink)
Old 01-25-2012, 08:34 AM
The arms and the top were built to pivot in sections:
  #26 (permalink)
Old 01-25-2012, 08:37 AM
Very cool, yeah I was thinking it was something like that. Nice work!
  #27 (permalink)
Old 01-25-2012, 08:39 AM
Thank you....
  #28 (permalink)
Old 01-27-2012, 09:47 PM
put up or shut up
nice work. I envy all that clean metal. Sometimes we get turds we have to shine and there's no good metal to weld too. Nothing like a nice clean well penetrated weld on clean metal.
  #29 (permalink)
Old 01-27-2012, 10:09 PM
graydog's Avatar
Is that butt weld safe?
  #30 (permalink)
Old 01-28-2012, 08:05 AM
He took those blades, put them back on a 100hp farm tractor and cleared 40 acres of treas and woods this past summer with these blades. I would say yes.
Tools for welding test rpjn59 Hotrodding Basics 7 07-31-2011 06:46 PM
Expensive Tools Vs. Cheap Tools car2shirt Garage - Tools 32 09-22-2010 06:03 PM
SK tools Mr.NutCase Garage - Tools 5 04-25-2009 04:55 PM
Butt welding vs Spot welding 69ChevelleAddict Body - Exterior 19 05-04-2008 01:47 AM
Tools? ToYoungToCare Interior 0 07-06-2003 08:13 PM
