cut wire, clean out nozzle, proper size for unscrewing both the nozzle and tips,
pliers for grabbing stuff (wire included) they are the mig swiss army knife they are nice to have mine are always right there on the front of my welder, sitting in the handle
I have always approached this slightly different. When helping a guy the other day do some stitch welding. When the wire would hiccup, he stopped, cut it then tried again. It was nothing but a re-occurring train wreck of false starts.
I sat down and put the grounding clamp close to where I was working. I explained that when I cut the wire off by touching the edge of the wire to the grounding clamp and pulling the trigger. Never a false start; always an immediate solid start. He said "I don't get it". What I showed him was, if I did it that way THEN waited 3 seconds I got false starts. BUT....If I cut it close to the weld site, then started my welding immediately all I got was clean starts. The key was, with a quick cut - then weld, the gas is at the tip ready to shield the weld....If I cut the wire with cutters OR cut it by dragging the wire on the clamp with a 3 second pause, the tip was not purged and the starts were not as easy. I have actually been thinking about modifying my welder to start the gas briefly before starting the welding if I chose to for stitch welding and such. |
That is interesting, but I honestly think you say toemato I say tamato. Cutting the wire on the ground clamp and then starting a weld doesn't take any less time than cutting it with wire cutters and then welding. When you cut it with the wire cutters you get a perfect "stickout" every time. You bring up an interesting point, because I do hit the trigger every single time. I hit the trigger, cut the wire to a perfect stick out and weld, done deal, we are talking a second or two tops.
But if you cut it off by burning it on the edge of the clamp you aren't going to end up with a perfect stick out every time. At least not until you get real good at it. Thanks for pointing that out, that is exactly what I do but forgot to ever mention it, hit the trigger, cut the wire and then weld. Brian |
I am pretty stuck in my ways, I am not sure I can go and get a pair. But I will keep an eye open and pick up a pair. Brian |
Honestly you would be hard pressed to clip it with cutters and go straight to the weld in the short amount of time then cutting it off using a grounding clip next to the weld with both hands already in position. The further you physically move the tip the more shielding that is loss as well. Very little movement and very little delay is optimum. |
they are the sawsall of mig wire tools
wire feed welder
Hi,northern has a wire feed welder (not mig) on sale for $139.00(110 V)
Another great tip is super ample amount of light. I use a self darkening helmet cause I like to see what's going on but it's STILL not light enough for my liking so I have this little tiny shop light I tug around me and I can see everything. My welds are much cleaner since doing that. I also use that same light to shine it on the backside to check for pinholes. Guys at the shop must think I'm a diva when I tow around that light. |
| Recent Garage - Tools posts with photos |
| Tools for welding test | rpjn59 | Hotrodding Basics | 7 | 07-31-2011 06:46 PM |
| Expensive Tools Vs. Cheap Tools | car2shirt | Garage - Tools | 32 | 09-22-2010 06:03 PM |
| SK tools | Mr.NutCase | Garage - Tools | 5 | 04-25-2009 04:55 PM |
| Butt welding vs Spot welding | 69ChevelleAddict | Body - Exterior | 19 | 05-04-2008 01:47 AM |
| Tools? | ToYoungToCare | Interior | 0 | 07-06-2003 08:13 PM |
