little VW issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2010, 10:19 AM
Wiki Edits: 31
little VW issue
1 thing I guess I overlooked on my '74 Super Beetle b4 I bought it was the sway bar mounts, being rotted off.. and the sway bar supports the suspension, so it's gotta be fixed.. can I move the mounts inboard more into good clean solid metal, and then just finish off the rotted parts and tie them back into the solid metal?
Old 08-01-2010, 10:42 AM
Wiki Edits: 31
anyone?.. what I'm thinking is getting the wheelbase correct for each side ( right now the struts will pivot 3" ither way.. then marking it and building sway bar mounts just inboard of the originals, and I'll just restructure it
Old 08-04-2010, 04:05 AM
you mean the strut torque rods ( the peices that hold the balljoint/lowercontrol arm in line??) I wouldn't mess with those as they help determine the caster/camber of the struts . and moving them inboard will change the akerman angles of the steering , I would find a donor and cut and replace it to original .
Old 08-04-2010, 07:27 AM
Wiki Edits: 31
no. the but Super Beetle does use the sway bar basicly as the strut rods.. the only adverse effect to moving them inboard that I can figure is a little more body roll.. once I get the wheelbase equal and correct on each side, then the struts will be in the correct position... theres a possibility I could fix the old mounts but I havn't really looked hard at the damage and how to fix it
Old 08-21-2010, 11:39 AM
Wiki Edits: 31
I reconstructed the old mounts with some plate steel which I bolted into good metal
56 Chevy Speedometer Calibration issue oldchevy1956 Transmission - Rearend 4 07-06-2010 05:27 PM
Possible Carb Issue? jvest Engine 12 05-29-2010 05:03 AM
Thanks Sprecher48 for VW engine basics wiki article Jon Engine 1 05-05-2008 02:08 PM
10-12 Bolt U-joint Issue Issue MrB Transmission - Rearend 3 09-29-2007 08:17 AM
'88 Plymouth Voyager starting issue (long) TooSlow Electrical 11 01-21-2007 07:27 PM
