"LL" TAG ON 1963 T-10 TRANS - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2011, 11:24 PM
Hi, I have a Chevy aluminum t10 that has some id numbers that I don't know what they mean: on the side cover has a metal tag stamped with "LL" bolted to a side cover bolt. what dose "LL" mean? second the case stamp says WG833 which what I found w= Borg Warner g= month but I found some info saying "g" along with some other letters are omitted 8= 8th day 3= 1963 3= 1,2,3 shift. so is "g" really omitted from alphabet to represent month...? FYI side cover prod date stamp= 5 2 63a, tail prod stamp 4 12 63, tail cast is t10-7d , main housing t10d-1. Any help would be great. Thanks
Old 02-23-2011, 08:29 AM
Its hard to know what someone has put in that case after 40-odd years
If you buy a rebuild kit for this trans, remember that this has the 207 maindrive (input) bearing and the input is held on with a nut.
To definitively ID this, count the teeth on the cluster gear after you open the side cover.
Heres a link to a parts diagram, it might help you
http://autogear.net/pdf/T10Catalog/T10 booklet.pdf
Old 02-23-2011, 09:22 AM
SSedan64's Avatar
That link doesn't work, try this one.
http://www.autogear.net/pdf/T10Catal...%20booklet.pdf
Old 02-23-2011, 12:41 PM
Sorry about that...
As far as the LL tag; I asked my boss who is an authority on the T10 and he doesn't remember an LL. It could be a builder tag, or an aftermarket gearset
Old 02-23-2011, 08:45 PM
Hey,
Thanks for the info so far. Here are some pics that might help with my questions
Name:	side cover.jpg
ID:	52965   Click image for larger version
ID:	52966   Click image for larger version
Strange thing happening with my clear "solvent pop"/"fish eyes" ? myfamiliacc Body - Exterior 35 02-16-2013 08:18 PM
1956 OLDS"98" trans swap questions gsuperdave1 Transmission - Rearend 5 10-31-2010 10:31 AM
95 GMC Safari auto trans "SLAMS" into drive rango25 Transmission - Rearend 2 03-30-2008 01:28 PM
Purchased an "OLD" GM Hydra-Matic Trans.. Bud's 27 T Touring Transmission - Rearend 1 06-02-2006 06:58 PM
Hey croz look """"IMPORTS SUCK""" 78 monte Hotrodders' Lounge 14 08-30-2002 02:13 PM
