lo/reverse piston probelm - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2012, 06:30 PM
90 700r4. i installed a new lo/reverse piston, new ones part number is 8685550 and the old one was 8663888. with the new one installed when clutches and steels and center support and snap ring are installed. go to air check the park reverse hole with minamal psi. and it has the slightist bubbling around the big outer seal on the piston i tryed the old piston and tryed puting the new piston in another case and even new seals. is this normal. possable that too much assebly grease preventing it from sealing 100%? i mean it still holds pressure but it just has a slow leak around random parts of the seal? any suggestion?
Old 01-23-2012, 08:34 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Not uncommon for minor air leaks... You may have scuffed the rubber seal slightly or the sealing surface of the aluminum has minor scuff marks
Old 01-25-2012, 11:01 PM
ok. so i might be able to get away with the slight leakage ur sayin? and another thing, this case does have over 200k miles on it. maybe its just worn. be i think im just gunna try a new set of seals and see what happens, i also use the spring compressor to help push the piston in place, maybe thats not a good idea but it seems no harm. any recommendations on seal brands?
TBI 454 Going in an 1985 1 Ton Dually wiring probelm c65shoebox Electrical 0 09-19-2011 08:09 AM
Early 87 700R4 Low / Reverse cluth piston drstrader Transmission - Rearend 13 04-03-2011 03:47 PM
low reverse piston seal th350 jeffvega Transmission - Rearend 2 02-17-2009 07:51 PM
Qustion on Reverse Piston seven1nova Transmission - Rearend 9 04-09-2008 08:14 PM
THM350 Question-(low/reverse piston) biggeazy-e Transmission - Rearend 2 09-24-2006 09:00 AM
