most all brake calipers re manufactured or new come ready to install mt definition of a loaded caliper is when the caliper already come with the pads in the box .
so that being said i dont know what he's talking about because most of the time the loaded calipers come w/ the cheapest pads obviously the price dictates the quality (most of the time) so organics; cheep semi metallic: better ceramic ; best hope this helps sr66
"SlowRide66" "Illegitimis non carborundum" Don't let the bastards grind you down! Crankshaft Coalition Master List of Hotrodding Forums |
But you can get Wagner Thermo-quiet loaded calipers which come with the Thermo-quiet pads which are what we use when we change calipers... (good stuff...)
With cheap pads come problems so we stay away from such... |
thermo quiet?? where r they on the pecking order?
sr66
It is probably a lack of communication between your sister, the technician, and you. Very common... usually ends with me getting yelled at.
Lack of communication ended up with your sister believing her calipers currently on the car are not loaded. Well, they're not. That is a term for something in a box. It is the kit-n-caboodle. Loaded calipers usually come with all the brackets, pins, and hardware, as well as pads, etc... All calipers you would buy would come with the piston installed, loaded or not. If the caliper is seized on a pin in the bracket, or the bracket is bent, missing hardware, maybe severe rust, etc... The easiest and least expensive solution might be a loaded caliper. Or He is recommending calipers as peventive maintenence, and selling a loaded caliper saves you on individual hardware and pin prices, insures it is all new, and saves you on labor, as well as makes his job easier, and reduces the chance you'll come back with problems. Or, the tech is just a moron ![]() Thermo quiet are an excellent steet pad for customer satisfaction IMO. |
| Disk brake caliper & steering arm hitting | gator412 | Suspension - Brakes - Steering | 3 | 05-28-2005 10:31 PM |
| Stuck caliper on 79 chevy | AMDAP | Suspension - Brakes - Steering | 2 | 10-30-2004 05:44 PM |
| Caliper hanging causing pull while braking | RAW | Suspension - Brakes - Steering | 4 | 07-12-2004 10:24 PM |
| Ford Explorer Brake Caliper Problems | Jag Daddy | Suspension - Brakes - Steering | 4 | 05-08-2004 12:48 AM |
| Best Ford caliper for 11" rotors on Mus II IFS | Darkman270 | Suspension - Brakes - Steering | 12 | 03-06-2004 04:20 PM |
