We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 01-26-2003, 06:58 PM
hiljak hiljak is offline
Post loading up,,sbc
i have a sbc in a truck i just purchased,,no matter what i do with the timing or the carb it loads up, when ya give it throttle it doesnt smoke (black) until it comes back down or the next time you give it gas,,blows alot out then,,if you double tap it,,it is bored .040,mild cam(no idea yet)its not stock though,stock heads,rpm intake,edlebrock 600 carb,,i have tried everything i know and nothing works ,,any ideas,,i think im overlookin somethin
hiljak
Old 01-26-2003, 07:37 PM
BOBCRMAN@aol.com BOBCRMAN@aol.com is online now
Post
the pistons that operate the power enrichment are probably stuck or the metering rods are not in the correct place in the carb.
Old 01-26-2003, 09:38 PM
Post
ill play stupid,,,the last time i rebuilt an eddy carb the metering rods were bent from inproper install,,you say not in the right place,,hows that??? and are ya talkin about the accellerator pump or somethin different,,school me ,,thanks again,,,hiljak
Old 01-27-2003, 10:52 AM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
2nd Gunman On The Grassy Knoll
Post
check fuel pressure, if you`ve covered your bases on everything else and you know the carbs right, if you haven`t checked fuel pressure is the next logical step, I ran into this problem like yours with a stock pump, 14 PSI fuel pressure at idle due to a bad cam fuel pump lobe.
Old 01-27-2003, 12:06 PM
4 Jaw Chuck's Avatar
4 Jaw Chuck 4 Jaw Chuck is offline
Post
Any reversion over the carb when this happens?, reversion is a kind of fog that gets ejected when there is alot of overlap in the cam and the engine is loaded heavily at low rpm. What happens is the fuel air mixture ends up going through the carb more than once enriching it each time leading to a very rich mixture.
What do your plugs look like?
Outlawed tunes from outlawed pipes
Old 01-28-2003, 12:50 PM
Post
there is none of the revision,,i just figured out i did have timing problem and fixed that but it only helped a little above idle,,im not sure if the carb is right on though,,on the pass side mix screw it has one spot in the adj. where it wont bog the motor and the dr. side screw can be moved a good bit,,common sence tells me that my problem is in the carb but i have had fellers tell me eddy carbs are like that,,oh yeh put a regulator on it just for kicks im runnin 5lb of pressure,,any other ideas,,thanks
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
