Locating the center, for a rotisserie.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2004, 09:45 AM
Pencilneck314's Avatar
Crap, hand me the grinder!
Last journal entry: Back on track
I'm building a body rotisserie and was wondering how do you find the balanced center of your car, so you can mount it properly on the rotisserie? Guess? Do you just make sure you have some adjustment holes drilled, so you can raise it or lower it, if you need to?
I dunno ,
Pencilneck314
Thanks in advance for any replies
Old 02-17-2004, 10:46 AM
Gearhead forever's Avatar
I just guessed when I built mine. It worked okay with a good sized bar to control the rotation. The adjustable centering sounds like a good idea if you plan on using it on many different vehicles over the years. If I made another rotisserie, I'd keep the bore from being to sloppy on the axis, it caused some binding. Now if I only had a lathe...
Old 02-17-2004, 02:50 PM
diablos_50's Avatar
New Member
post some pics when you get it built!
Old 02-17-2004, 03:04 PM
Not my design....
I got the plans here....
http://members.tripod.com/~mopar_roa...otisserie.html
I've seen several plans, but these look to be the best. This one was made for a charger so, I'm having to figure out a different configuration on the pieces that attach to the frame.
Pencilneck314
Old 02-17-2004, 07:58 PM
Sandflea427SS's Avatar
Anything with a throttle
If BattlestarOne doesn't see this in the next few days. Send him a PM....He could fix you up with info!
Old 02-17-2004, 08:23 PM
Will do...
I'll go ahead and send the PM.
Thanks,
Pencilneck314
Old 02-18-2004, 01:28 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Don't worry. You build it according to the plans....when you fasten it to the car it will rotate. When I had my '62 on one I thought it would never spin, but it did with one hand. Look thru my photo album and I have the same pics and then some. I can also send you everything I have in the way of plans. About 5 different types including the one you have now.
Kevin
Old 02-18-2004, 09:08 AM
Thanks everybody...
Good deal, Kevin. Thanks to everybody who posted. Sandflea I got good responses back from BattlestarOne too. Thanks for the recommendation.
Pencilneck314
