Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - location of Reverse Oil Port
Old 03-29-2013, 09:21 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
the hole next to the marked one (on right) is also a port... air will come out of a bolt hole too.
There are 3 rubber seals on the piston in the case. that creates 2 sections on the piston. One is reverse , the other section is used for manual 1st gear
