location of Reverse Oil Port - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2013, 08:29 PM
Everybody talks about this port that's used with compressed air to both remove the rear piston AND check that it's working correctly after rebuilding it.
Only thing is Nowhere is there any information on exactly WHERE this port is.....lol.......
Even Session's book doesn't have a picture........although he refers to the 'illustration'......lol
Anybody got a clue?.....a picture would help.
z
Old 03-29-2013, 08:37 PM
OK........I found it:
z
Old 03-29-2013, 09:21 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the hole next to the marked one (on right) is also a port... air will come out of a bolt hole too.
There are 3 rubber seals on the piston in the case. that creates 2 sections on the piston. One is reverse , the other section is used for manual 1st gear
Oil cooler location/oil capacity redneckhotrods Engine 0 10-19-2012 11:42 AM
1993 Chevy 5.7L TBI heater hose port location Infinite Monkeys Hotrodding Basics 9 03-02-2012 06:08 PM
need help on oil filter location goth_rod87 Engine 8 06-06-2005 06:53 PM
Oil in vacuum port bct Engine 4 12-29-2004 07:18 PM
Reverse Port The Vandal Engine 3 04-26-2004 10:02 PM
