Location for Vega plate / unisteer - 32 ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2006, 03:54 AM
Last journal entry: Bringing home the 401 Nailhead
I now have my unisteer unit and a weld on "Vega" plate for my 32 Ford 2dr sedan w/cross steer. What I am missing is any template/measurements on where to put the "weld on" plate. Contacted the dealer - said something about so many inches from the spring but wasn't sure on exact measurement. He said he would check with his frame manufacturer. Is there any measurement or better yet a template?
Old 11-07-2006, 06:28 AM
These are mine ...
I do not remember exactly the measurement from the cross member but I will measure mine later today ... if that helps.
Deuce ...
Old 11-07-2006, 06:09 PM
I went to the shop today and measured the distance on mine ...
If you measure between the center of the radiator mounting hole in the front cross member and the center of the top mounting bolt ( of the three that holds the bracket to the welded bracket ) I measured 10 inches ... exactly.
Old 11-08-2006, 04:21 AM
Thanks again Duece. When I get this on the road will have to dedicate the first ride to you.
In your pics it looks like the leading edge of the bracket is vertical in relation to the frame. It also looks like your drag link is parallel to the axle.
Guess I will wait for the rest of the front end parts to come in and mock up before tacking the vega plate.
Old 11-08-2006, 06:13 PM
My 4 bar bolts do not have the nuts on them ...
I want to align the front end and I do not want to use the Ny-Loks but once ... so I will put the nuts on ... after the 32 has a 4 wheel alignment.
Old 12-29-2006, 06:36 PM
Deuce, i noticed you have what i think is the mount for a front panhard bar. what do you use for a mounting location on your axle? Also.. for the tie rod ends , and rack ends(draglink).. is there an aftermarket end you can use other than say ones from a streetrod supplier? What i mean is , suppliers up here are a little hard to come by, so i was wondering if the ends are something you could order from say a NAPA store? or am i better off just ordering the whole set up from a rod supplier?
Old 12-29-2006, 09:04 PM
I bought everything but the frame rails and the 9 inch Ford from TCI ... in California ...
Old 12-30-2006, 09:00 AM
Ok, great. thanks i'll check out the web site and maybe i'll have to order that stuff as well. Thanks for the quick responses by the way
'32 ford question bonuts Body - Exterior 9 02-18-2009 03:23 PM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
'32 Ford Truck Windshield Wiper Systems rcrfly General Rodding Tech 2 08-12-2006 08:50 AM
32 ford frame width at front axle centerline Dirty Steve Hotrodding Basics 4 05-15-2006 07:40 AM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 07:36 AM
