Lock up? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2007, 02:19 AM
BMM BMM is offline
Lock up?
Hello. Im shopping for a new transmission, and I've come across "Lock Up or Non-Lock Up". What exactly is this? My understanding is lockup is better on fuel, becuase of less slippage on the highway?
1988 Cutlass Supreme with the factory 200-4r transmission. Would that be lock up, or no? And Does the converter dictate lockup, or the transmission?
Thank you.
Old 09-25-2007, 04:34 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
The 200-R4 uses a lockup converter, and yes the lockup will reduce slippage when engaged. You will see about 200 to 300 fewer rpms when locked.
A non lockup converter can be used, but I don't recall if modifications to the trans has to be done to run it. One of the trans experts will be able to tell you.
Old 09-25-2007, 10:08 PM
BMM BMM is offline
Thank you. So, Ill definently go for Lock Up I guess.
Why only one door lock on a Ford F-100? Z-Money Pit Hotrodding Basics 38 12-30-2011 05:44 PM
Chevy 4 speed lock nut? dh79 Transmission - Rearend 8 01-07-2007 05:24 PM
Anyone ever had a line lock fail and degrade braking? sizemoremk Suspension - Brakes - Steering 7 09-22-2006 02:13 PM
89 dodge dakota anti lock and brake light on notmrgoodwrench Suspension - Brakes - Steering 14 06-05-2006 08:41 PM
