lock up - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2006, 08:24 AM
New Member
lock up
can you put a non locking converter on a 700r4 that is set up for a locking type?
Old 02-05-2006, 09:40 AM
Crosley's Avatar
Wiki Edits: 1659
it is best to have both tranny and converter match so the oil flow paths are correct to avoid over heating the tranny
Old 02-05-2006, 09:55 AM
New Member
lock up
whats the advantages and disadvantages of both?its gonna be used on the street.
Old 02-05-2006, 10:20 AM
Why do you want to run a 700R4 setup for a locking converter without one?
Old 02-05-2006, 11:51 AM
tnsmith10's Avatar
when will it rain???
i run a 700r4 in my car with a non-lockup converter., been in the car for going on 10 years now and have had no trouble with it at all... even been to the east coast and back. (23 mpg with an inline 6 with a 500 cfm edelbrock 4 barrel carb)
the reason i went with the non-lockup was a) i didnt want any electronics to get in the way, b) didnt want to do the checkball thing with tcc apply in 3rd, and c) i already have 2.54:1 diff gears so i dont need a lockup anyway, but wanted the low (3.07 ) 1st gear.
to each their own..
Why only one door lock on a Ford F-100? Z-Money Pit Hotrodding Basics 38 12-30-2011 05:44 PM
350 lock up transmission str8_57 Transmission - Rearend 7 02-13-2006 06:28 PM
Problem installing line lock airman_turtle Suspension - Brakes - Steering 3 07-04-2005 10:35 AM
cam lock plate Blob Engine 2 05-07-2004 11:30 AM
steering column lock swap steve bird Suspension - Brakes - Steering 7 10-18-2003 05:52 AM
