Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - lock-up convertors
Old 12-06-2002, 09:12 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Post
I did something similair to a TH350C. if memorey serves, the front wire is positive, the rear is the negative, you can run it to a toggle switch as I did, or you can order a kit to make it work normally. I`m still foggy on for sure if the wires are right, so maybe someone here can refresh me if I`m wrong.
