locked advanced question? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2006, 07:30 AM
ok i have a holley billet distribitor with the hall effect. magnet in it. this dis. has no macanical or vacum advanced , why? what do they use these for, i read some wear just for racing. do they sell ign boxes that control the timing curve? where should i set the timing at low rpm?i dont think it will ideal under 1000rpm i doont no never got it crank yet. 10.5 / 1 compression.can any one answer my questions??????????
Old 05-11-2006, 09:00 AM
johnsongrass1's Avatar
Race it, Don't rice it!
What's your part no.
Some Holley's have a lock out feature. Yes it's pretty much a race only thing. Makes for very hard starting.
Old 05-11-2006, 01:46 PM
part number is 890-101 so this set up will suck on the street. i only plan on driving 1 or 2 times a week maybe. or more. i heard msd has a retard timing on starting. i read that some boxes control timing on each cylinder. so is there a box that can control my ign curve on my locked advanced ?????????????????? do they sell macanical cuve kit for my holley dist.?
Old 05-11-2006, 03:21 PM
I don't know. I couldn't find anything on the holley web site about that part No.
My guess is it's a computor controlled dist with no advance mech. I would call holley and see what they say about it.
Old 05-12-2006, 06:07 PM
Put a toggle switch on the dash , between the distributor and the power source.Crank the ignition for a second and then flip the toggle(power) on. It will start easy. This won't do anything about it running on when you turn it off though.
Old 05-12-2006, 08:18 PM
ok well i got a new msd macanical distribitor. fires right up now dont have any problems now. the only problem i have now is belt squealing melted it then snapped it. put a new belt on tighten it real good the squeling stop.
Old 05-12-2006, 09:09 PM
65Stanger's Avatar
Check the water, check the oil
Sounds like you don't have a problem then.
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 07:35 AM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
