locked out timing
What is the advantage or disadvantage of locked out timing?
street strip chevy 355, 284 cam 3000 stall, 195 heads, 750hp 150 nitrous. Run 37*. I do have a timing control that will let me knock it down on start. |
What do you base those HP estimates on, or is that a 750 HP carb you're talking about? |
carb
yes it is a 750 hp holley, I bet you thought I was crazy. I have 308 to the rear on motor. I have my timing in at 3000 do you think that is good or go lower 2400?
3000 might be a little high, but a LOT depends on the gears, weight, use, gas, etc. Hard to just say more will work- but IF the engine and gas will tolerate the timing in sooner, you could do it. I'd at least try to bring it in a little sooner, until you get indications of detonation- then back it down some until you're safe. |
| Distributor Tuning and Theory - Part 1 | Rick WI | Engine | 35 | 04-26-2011 12:38 AM |
| Timing Timing Timing | bigcountry1009 | Hotrodding Basics | 6 | 01-20-2009 05:47 PM |
| What the ***** is wrong with my timing cover/ harmonic balancer!!! | sexypizzaman | Engine | 56 | 10-28-2008 03:49 AM |
| timing | itzvern | Engine | 2 | 09-22-2006 06:05 PM |
