Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - locked out timing or timing curve?
Old 08-04-2012, 06:41 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
You want to give the motor all the initial it needs to idle correctly
for that cam I would try 18 to 25deg at idle. Short mechanical advance curve.
The 273's must suck. That thing would fly with 4.10's
you need to get a vacuum advance too.
