locked timing help - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2011, 10:33 PM
locked distributor timing help
i have searched the forum and google to try to get the answer to my questions but havent really gotten anywhere. I have a sbc 350. I pulled my distributor out to change my intake gaskets, and while the distirbutor was out i decided to lock it. im going to set my timing to 32-34*. now my question is, do i need to put the #1 at TDC or BTDC? from what ive read, some people said BTDC and some said TDC... im not sure what i should do... question #2 is, i ordered a new digital timing light, when i set the light at my desired timing (32-34*), the light digital light will read "0" when my timing is where i want it correct? thanks for the help. - David
Old 01-19-2011, 02:52 AM
SSedan64's Avatar
#1- You want #1 @TDC.
#2- Yes, 0* if you're using a Dial Back timing light.
Old 01-19-2011, 06:31 AM
alright, thanks for the help.
Old 01-19-2011, 10:31 AM
What is the reason for doing this?
Locking the timing at some maximum advance is used for really radical camshafts in engines that run full tilt.
The timing is set according to Top Dead Center such that it precedes that event. If this is a Chevy this can be set for the number one cylinder, however, number 6 can be used as well.
You will find an engine with locked timing can be quite difficult to start and tends to be hard on the starter. A way around this is to separate the starter and ignition functions such that the starter can spin the engine up then the ignition turned on.
Bogie
Old 01-19-2011, 06:45 PM
Not only that, but it will have a greater tendency to knock at lower rpm, and without a vacuum advance you'll absolutely kill your gas mileage.
Of course that's if it's a street vehicle.
Old 01-19-2011, 07:23 PM
bubbahotep's Avatar
Assuming the 350 is not stock, and has a somewhat choppy cam, the locked timing wont be too bad except for really hard starts (depending on your compression ratio). You can search the forum and go with an ignition OFF switch to avoid that.
Your only issue, at first, is replacing the dizzy. You wont know what the timing is at until you can fire it up and use the timing light. You might be way over 35* or way under 0*. Just locking the dizzy weights doesnt set the timing, its when you rotate the dizzy that the "locked" advance comes in. Then you tighten the bolt to hold the dizzy when you are at the timing you want. Does that make sense? I have mine locked but if I were to turn the dizzy I could advance or retard my "locked in" timing.
Old 01-19-2011, 09:11 PM
nastynova's Avatar
I run my timing locked at 36*... car is drag only and has a MSD box that has a start retard function... only note I have is that if you have a "box" most dial back timing lights dont work well with them... good luck...
locked out timing tomthecomic Engine 3 01-29-2010 10:01 PM
Locked timing problem Biscuit6447 Engine 4 10-02-2009 11:33 PM
Locked Out......Yet Again malc Hotrodders Site Suggestions and Help 8 05-07-2008 11:09 AM
Should ignition timing be locked out for drag racing? chevyv8_power Engine 2 05-04-2008 01:33 PM
