Lockheed BAI Master Cylinder nightmare - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2008, 04:12 AM
69 Ford Ranchero
i have a Lockheed BAI N177 master cylinder fitted on a 69 Ford Ranchero (Aussie Falcon XT UTE) that is giving hassles.
new master cylinder kit was installed along with new reservoir cups.
cylinder has been resleeved before and is in good nick.
problem:
when you dry pump it, there is pressure on front and back wheel exit holes.
when you try and bench bleed it, you only get fluids coming out the exit hole for back brakes.
i have stripped it again, cleaned it out again, used compressor to blast holes clean, but still no luck.
only the back brakes bleed.
can anybody give me advice please? my patience has run out. Angry this is the last thing holding up the build.
the easiest would be to just fit discs in front and convert the whole system, but my money is done.
heeeeeeellllllppppppppp!!!!!
Old 08-26-2008, 04:46 AM
69 Ford Ranchero
sorted. was a missing rubber seal in the seal kit.
works like a treat now.
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 06:15 AM
Master cylinder without booster? Rons1stRod Suspension - Brakes - Steering 16 11-05-2007 10:06 PM
Master Cylinder Help Needed glg97 Suspension - Brakes - Steering 2 11-06-2005 08:20 PM
39 Deluxe master cylinder adapter? MM in NM Suspension - Brakes - Steering 4 09-30-2005 04:42 PM
Stang master cylinder Old Crow Suspension - Brakes - Steering 3 06-10-2002 01:40 PM
