Locking a 12 bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-26-2005, 11:58 PM
Locking a 12 bolt
I have what i believe to be the stock 12 bolt in my 73 K10. When looking at it it seems to have some kind of limited slip. I want to put a lock right in the diff but i guess they are only for open carriers. Was wondering if my carrier would work and if not what path i should take to get a lock right in the rear of my truck.
Old 06-27-2005, 03:48 PM
chrisflock's Avatar
Last journal entry: A quick trip
Is there something wrong with the limited slip you currently have? I would try to find out what type it is, first off, and go from there.
From what I've been told, the lock-right system isn't really the way to go in a performance car, as it is a fairly inexpensive unit, and will give you the whole tire-chip and ratcheting in turns thing...
However, if this is what you are looking for, I would bet you could get someone to trade you an open carrier for your limited slip unit. In fact, if you had a 10 bolt, I would trade you, even if the unit you have needs to be rebuilt. (I've got 2 or 3 nice 10 bolt carriers that are open, and was seriously considering putting a lock-right into my truck, until some people here explained how they work...)
Chris
Old 06-27-2005, 09:55 PM
i wanted the lock right because i will be using the truck mostly off road in muddy terrain.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
New 12 bolt rear? strikingthematch Transmission - Rearend 3 07-28-2004 11:41 PM
10 bolt to 12 bolt 1980Impala Transmission - Rearend 8 04-25-2004 04:48 PM
How to identify Oldsmobile 12 bolt? elukas Transmission - Rearend 8 12-13-2003 10:59 AM
just swapped to a 12 bolt and the yolk is wrong! Destructo Transmission - Rearend 6 10-14-2003 08:54 PM
