locking lug nuts - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2010, 03:15 PM
Busy building
locking lug nuts
My mustang has locking lugs nuts on it. I wasnt aware of this at the time i bought it and the person i bought it from doesnt have the key. Does anyone have any suggestions on how to remove them with out buying the special kit.
Old 07-28-2010, 03:22 PM
delawarebill's Avatar
locking lugs
if they are the type that takes the key at the very front of lug??? meaning they have a scroll in the front... u can take a socket a nats butt smaller and hammer it on.. put in vise and use a rod or something to knock it out.. use it on another. if its the rotating collar type..not sure of that one.
Old 07-28-2010, 07:13 PM
Wiki Edits: 31
buy a set of keyed lugnuts from walmart.. I bet those keys will fit enough to get them off
Old 07-29-2010, 11:27 AM
I had this problem on a truck that I bought. Take a regular lug nut and arc weld it to the end of the lock through the hole in the lug nut. This should give you enough grip to loosen the lock. It worked for me.
Old 07-29-2010, 02:41 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Some technicians, (like myself), have special sockets for removing locking lug nuts, kinda like an external EZ-Out, maybe call your favorite garage and see if they can help you, if they have the right tools, it only takes a minute or two to get them off.
Old 07-29-2010, 06:50 PM
T-bucket23's Avatar
Wiki Edits: 26
Any tire place should have the tools to get them off. Most mechanics also wil have the special sockets. I have also seen a nut welded on but would not recommend this if you have nice wheels.
Chet
Old 07-29-2010, 08:40 PM
Actually, in my case they were aluminum wheels and there was no damage to the wheels. I did take care to protect the area around the lug from weld spatter, but with the stick inside the outer lug nut, there really was no problem.
Old 07-30-2010, 10:37 AM
Simply getting a slightly smaller impact socket (one you have no love for) and hammering it onto the lug will often work too.
Another trick is an air chisel and get on the edge of it to rotate it left. Did that with a mechanics air chisel on a rental car out on a country road at a gas station when I found there was no key in the car.
Old 07-30-2010, 10:58 AM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
Check the glove box before you do anything like this. I had a car that I bought with wheel locks and the PO didn't have the key. It was in the glove box. If you can't find it in there, I'd just follow Mr. Padavano's advice.
Old 07-30-2010, 11:15 AM
Tire store
The previous entry about going to a tire store is best. The guys at a place such as Discount Tire will have the special sockets to get 'em off. That problem presents itself all the time at those stores.
Get rid of the locks or you may be stranded somewhere when a locking lug nut breaks when you are attempting to loosen it. Never tighten a locking lug nut to the same torque as the rest of the lug nuts. Torque the locking lug nut to no more than 40 lb. and just use them as a "scare-crow". Merely the presence of locking lug nuts will be a deterance to most thieves.
I never have used locking lug nuts because I never park my ride anywhere that is out of pistol range.
Old 07-30-2010, 11:29 AM
Busy building
ithink they aere factory because the outside is completley round
Old 07-30-2010, 07:41 PM
I tighten them all the way, HOWEVER, NOT with an impact wrench! Do them by hand only! Ask me how I know.
Hey I need the same size Ford lug nuts only smaller junkyard junkie Suspension - Brakes - Steering 4 02-08-2010 09:15 AM
Wheel studs and lug nuts lostinkandahar Suspension - Brakes - Steering 1 01-31-2010 10:51 AM
What kind of lug nuts?? 12second6 General Rodding Tech 3 09-16-2009 03:30 PM
Lug nuts for wheel studs lluciano77 Transmission - Rearend 1 10-26-2005 10:34 AM
What lug nuts for Torque Thrust 11 western star General Rodding Tech 3 10-16-2004 11:57 AM
