-   -   Locking Mech and vac advance on HEI issues (http://www.hotrodders.com/forum/locking-mech-vac-advance-hei-issues-176903.html)
maxpower_454 04-26-2010 06:12 AM
I got a plate to lock my vac advance. I took off the springs and rotated the weights and plate to full advance and tack welded it. Now for some reason when I rev the engine the timing will retard about 4 degrees. Anyone know why it would do this?
red406 04-26-2010 10:24 AM
Could it be the cam walking in or out?
cobalt327 04-26-2010 11:20 AM
Excessive end play on the distributor shaft will cause at least some of it. You want to set the play to ~ 0.017"-0.020". I've seen them over 0.100".
Mr Gasket and others have shims for the HEI. The shaft is ~0.490" OD.
What you're probably seeing is a combination of the timing set, distributor end play AND the cam being forced rearward.
maxpower_454 05-20-2010 10:23 AM
Ok so the tack welds broke on the weights. How else can I lock my mechanical advance?
BBCMudbogger 05-20-2010 10:59 AM
I just had to...seems like I'm more smart *** than helpful these days....weld it better?....just yankin yore chain man
speedfreak2 05-20-2010 05:46 PM
If you really want to lock out your HEI by welding it then simply remove the weights and springs and weld it. One of the reasons that your timing retards as RPM increases is the fact that there is a certain amount of "Dwell" built into the module hence the reason for centrifugal advance. You really should toss the module along with the weights anyways and get yourself an aftermarket ignition box and fire it off of the magnetic pickup.
After you weld the distributor you should make sure it is phased correctly. Pay someone to put it on a distributor machine. It can also be done in the car but it takes patience.
