Is This a "Locking" or "Non-Locking" Posi? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2011, 12:06 PM
texastomeh's Avatar
GM 7.5" 10 Bolt 28 Spline 3 Series EATON Posi Unit.
Unit was in a 2002 S-10 Blazer.
"They call it a limited slip. It will release on turns where only one gets the power and then on straight it will use both wheels."
I want to put this (hopefully it is a non-locking) in a 1980 Monte Carlo donor diffy (upgrading to 28 spline axles, of course) with 3.42 gears - strictly as a street cruiser.
Thanx in advance for your help!!
Tom
Old 12-30-2011, 02:46 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
its a clutch type posi, which would be a non-locking
will you have to buy those 28 spline upgrade axles?
whats it going into?
how much power is it going to have going to it?
Old 12-31-2011, 12:29 AM
SSedan64's Avatar
80 Monte 7.5" came with 26-spline.
28-Spline 8.5" Axles from a 84-87 Buick GN/T-Type or Olds HO/442 will fit.
Old 12-31-2011, 04:40 PM
If its an Eaton, then its a GovLock.
It will have 2 shafts with wieghts that swing out based on RPM.
Its an OK unit for street use but does not tolerate abuse.
The 28 spline axle in a 8.5 axle has a different button thickness than a 28 spline 7.5. You can grind the axle down to the same dimension as your 26 spline axles.
Locking down oil pump... Caballerokid Engine 11 05-13-2010 06:09 PM
locking out distributor 406MOUSE Engine 11 05-10-2010 06:52 AM
Need help with vapor locking Jmark Engine 12 10-25-2006 10:50 AM
GM 7.5 posi 26 spline 2 series Locking Diff 383MontecarloSS Transmission - Rearend 10 04-05-2004 06:35 PM
4X4 locking hub ID?!? ramjet Transmission - Rearend 7 01-08-2004 05:36 PM
