Lokar Alignment Problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2011, 02:37 PM
My 1936 coupe came with Lokar carb linkage to the footfeet...This car is new to me so be easy on me....I noticed the alignment going thru the firewall isnt exactly right and when accelarating the cable binds on the downside of the tube coming thru the firewall...a couple strands of cable are broken..to me it looks like when the accelerator is depressed the cable is slightly pulled down and catches on the bottom side of the tube...without redrilling holes is there something I can do to correct...I was thinking about some kind of angled washer or something to make that alignment better...thanks..craig
Old 05-30-2011, 03:11 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Hmm, I have LOKAR on the Nova but it goes out through the floor, under the pedal. Maybe you could remove the cable sheath and put a philips screwdriver the same size through the hole and push it down or lift up to bend the firewall face in the direction is has to go to make it a straight through shot? Just a thought.
I did something similar on my trans tunnel for the shift cable to go through at a shallow angle, worked great.
Semper Fi
Old 05-30-2011, 03:22 PM
A call to Lokar would answer your question, but I will try to give you some help. It is important to get the cable pulling straight through the guides. Sounds as though the previous installer did a good job of that up at the carb bracket, but either drilled the firewall too high or installed the pedal assembly too low. To keep from redrilling, elongate the holes in the mounting base of the throttle pedal if you are talking a small amount. If it needs to go up more than a quarter inch, you will have to redrill the holes in the toe board to get it high enough. If you have already frayed the cable, then you might as well order a new cable and housing since the housing is worn into the wire coil and will continue to eat cables since it is impossible to get a perfect straight pull. When I install this system, I have the cable slightly high at the relaxed position, perfectly centered at the mid range position and it will be slightly low at the WOT position. The cable tension at idle is minimal at idle and gets higher as you move toward WOT. Since you don't spend a lot of time or not as frequent at WOT as idle to mid range, you get the longer lasting cable and housing by applying this theory.
Trees
Old 05-30-2011, 03:29 PM
Thanks
I will call Lokar tommorrow and order a new cable assembly..at summit racing they are 42.95....I think my alignment is pretty minor and would opt towards elongating the two mounting holes for the accelerator....the accelerator would have to be raised about 1/8 of an inch...I thought the housing would have some kind of fitting at the end so this wouldnt be an issue...I'm not missing any parts am I?.....thanks again..craig...I'll post lokars commenst tomm...craig..
Old 05-30-2011, 04:29 PM
Irelands child's Avatar
As Trees mentioned and just the way the carb bell cranks work - the top is cruise, the bottom the tranny kick down. The throttle is a solid linkage back to the pedal as I really ran out of room for that Lokar cable with the engine setback, but the principle is the same:
Dave W
Irelands child
Old 05-31-2011, 03:10 PM
Called Lokar Today
They said about what I expected....relocate the foor pedal for better alignment...I moved it up about 1/8-1/4 an inch and at rest the cable is in the center of the hole...while running I looked at it and it doesnt travel very far when you accelerate so I think I'll leave it there....Lokar will be at our 50's event in a couple weeks so I'll buy a new cable from them...thanks again for your help craig
Old 05-31-2011, 09:23 PM
dinger's Avatar
And yet another problem solved from the good guys at H.R.com!
It never ceases to amaze me at the quality of our members and the help they provide. Thanks, guys!
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
head alignment problem goggo1957 Engine 16 03-24-2008 10:35 PM
'67 Nova SS alignment problem Kevin45 Suspension - Brakes - Steering 4 12-23-2007 02:19 PM
Intake alignment problem dastone Engine 8 06-29-2005 05:52 AM
Alignment problem 85 SS Suspension - Brakes - Steering 4 12-22-2003 03:02 PM
alignment problem on the 72 72 Z28 Engine 4 12-15-2002 01:27 PM
