lokar or gennie - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2008, 07:49 AM
lokar or gennie
Any pros or cons on these 2 shifters?
Old 04-07-2008, 08:12 AM
Frisco's Avatar
Glad To Be Here
I have used both and they both work very well.
You have an easier time selecting gearshift knobs for the Gennie.
Because of the push button feature of the Lokar you are limited in the selection of gearshift knobs unless you use an adapter that they have available. The adapter deters from the overall appearance though. (That's my personal opinion.)
Old 04-07-2008, 08:42 AM
bentwings's Avatar
bentwings
2x with frisco.
I prefer the Locar. I think it is smoother and the standard knob is ok by me. (no skulls allowed in my garage)
Here is the problem with either. If you have a tight auto and a strong motor, when you try to manually up shift it is easy to go too far as there are not any real position stops except for those that are internal to the trans. You can stiffen the valve body spring but it is a messy job at best and still only a bandaid.
I called about this, and Locar said they are working on a better gated shifter.
A gated shifter for the same price would be nice.
Old 04-07-2008, 09:03 AM
Frisco's Avatar
Glad To Be Here
I agree and should have mentioned this.
A better gated shifter would be a definite improvement.
Neither the Gennie or Lokar shifters are designed for racing and as such can be up-shifted from a low gear position directly into neutral (Not good) with just the flick of the wrist.
Old 04-07-2008, 09:06 AM
Irelands child's Avatar
I looked them both over before I purchased the Lokar. I do have to agree with bentwings about the lack of a good gate - but since I will not be doing any organized drag racing, felt that I could live with that situation. The Lokar is smoother, and has a much better and more solid mounting system. My biggest complaint - their instructions leave a lot to be desired. You will have to use a Lokar kickdown and probably their throttle cable - and I'm not sure that Gennie has those components.
This is my setup on a Ford C4 and includes the e-brake:
Irelands child
Old 04-07-2008, 09:11 AM
yeh, I bought a B&M megashifter,but its going to take up more room on the floor than I expected,I have a 26T and the floor is only about 3 feet wide. But now I don't thinh a locar or gennie would because I don't think I would hav room for the shiftrod because the MC is so close to the tranny that I had to use banjo fittings on it.I see locar makes a cable shifter now,but its a floor mount like the B&M is. How does the front bolts on the locar attatch to the tranny,I can't figure it out on their pictures,I might be able to make one work but not sure
Old 04-07-2008, 09:15 AM
streetrodderbn's Avatar
Certifiable Streetrodder
Just as an F.Y.I. I had a fittment problem with my lokar shifter hitting the tranny tunnel on the pass. side in my 37 due to engine setback, the easy fix was to buy an additional drivers side bracket that hugs the tranny tighter. The standard pass. side bracket is squared off for use of a tranny mounted handbrake. With only very minor mods, it works great, and now has plenty of clearance!(my e-brake is hooked to the stock 37 handle)
Old 04-07-2008, 09:36 AM
Take a look at a B&M 'Z' gate - I had one on a '23 'bucket. Fit real nicely: http://www.bmracing.com/media/catalog/1.pdf
Irelands child
Old 04-07-2008, 10:37 AM
XNTRCI-T's Avatar
AKA Lee in KC
I can't comment on Gennie... I have Lokar. Three comments about Lokar:
(1) There are two types of tranny mount for the Lokar, tail mount and plate mount. The tail mount has only one mounting position, the plate mount has four or five. The plate mount adds some height to the tranny installation, so floor/tunnel clearance can be an issue (it was for my '23 T). The tail mount would have worked better for my installation. The plate mount does give you a lot more choices on where you set the shifter in relation to your seating position, though.
(2) I have had a devil of a time getting the neutral safety switch set. It may just be my particular set-up (TH350), but it does not seem to be possible to set it where it is completely impossible to start in either Drive or Reverse. In other words, the range of adjustment is too wide and spans all of the Neutral position plus just a little bit of either Drive or Reverse, depending on which way you are adjusting. As was mentioned above, the instructions are pretty vague in this area.
(3) As was said above, this shifter is not good for manual shifting.
Old 04-07-2008, 12:55 PM
I can't use the tail mount and I don't know if I have clearance between MC and tranny for the left-front mounting bolt or the linkage?? can u tell by these pics?
ID:	29098   Click image for larger version
ID:	29099   Click image for larger version
ID:	29100   Click image for larger version
Old 04-07-2008, 01:12 PM
XNTRCI-T's Avatar
AKA Lee in KC
I think you're scrawed, bud. You might be able to get a cable shifter to work, but the set-up I have won't work with your MC.
Old 04-07-2008, 01:30 PM
Will these help? The shifter and plate remain basically the same regardless of the transmission, only the brackets and linkage change somewhat.
Irelands child
Old 04-07-2008, 03:03 PM
I have a turbo 350 and much narrower frame rails
Old 04-07-2008, 03:14 PM
Frisco's Avatar
Glad To Be Here
With the master so close to the trans I don't think any shifter (including the cable linkage) will clear.
You might consider moving the master further to the rear to give you the clearance you need. This is what I did on my Model 'A' frame which is wider than your frame. See picture below. Left click for a larger view.
Name:	remote master.jpg
Old 04-07-2008, 03:28 PM
My 4 bars are where your power brake unit is This car is really small,the b&m cable shifter will work,it just takes up more floor space than I realized it would ,I've allready moved it over to crowd my wifes feet,(boy is she happy about that ha ha) now if I can get my right foot made narrower somehow then I can work the gas pedel and the brake,maybe I'll put the gas pedal on her side !!!
Need Help, adjusting a lokar tv cable maninacoupe Transmission - Rearend 2 10-01-2006 06:25 PM
Lokar Shifter Bell Crank bartamos Transmission - Rearend 0 06-01-2006 10:41 PM
Gennie or Lokar A/G WILLYS Transmission - Rearend 12 06-01-2005 12:24 PM
Lokar trans mount E-brake 302 Z28 Suspension - Brakes - Steering 2 01-01-2004 03:31 PM
Can't get my lokar trans cable to fit. firewood Transmission - Rearend 3 08-22-2003 03:23 PM
